Brief Description: Sanding/Cleaning - Fiberglass in prep for paint
Finished sanding the putty on the top cowl this morning. Then I sanded the wheel pants and cowl with 800 grit and washed with soap and water. Sanded the filler putty on the rudder. Needs another coat of filler primer and maybe alittle more putty before it's ready for the big leagues.
Completed the wet sanding of the putty
Wet sanded all these with 800 and washed with soap and water
