-Started the nasty job of sealing the baffling with high temp silicon. I can't let air go anywhere, but into the cylinder fins, all other areas have to be closed off or you won't like the engine temps you'll see on your first takeoff and climb. I have a bunch left to do, but I was trying to use up a partial tube of goo I had left over from another project.
