Brief Description: Engine Control Cable Rigging / Hobbs Switch
-Put the hobbs meter oil press switch on the firewall manifold. I have to space the manifold 1/2" off the firewall for that sensor to fit (I have the other sensor for the EFIS). -Started working on finalizing the throttle/mixture/prop rigging - what a pain. The mixture and prop are good - although I need some non -A bolts for the cotter pins on the mixture cable apparatus. The throttle isn't going well. I just need to slow down and figure out which end(s) to adjust to get the right amount of throw in the right range.
Throttle cable - seems simple compared to the mixture, but....
Hobbs switch on the bottom of the manifold - EFIS oil press sender facing fwd. Oil line on top
