Brent s RV-8 Project N784DE
Date:  10-25-2010
Number of Hours:  1.10
Brief Description:  Snorkel #8 and Baffle #5
-Blocked off the inside of the snorkel so I could put in expanding foam for reglassing.
-Sprayed in the foam
-Re-made the alum angle for the back of the inlet ramp
-Drilled to match the ramp
-Deburred and c/s
-Rivetedd to the ramp. It is a combination of flush and std rivets due to the filter retainer brackets overlap
Limiting the are of where the expanding foam will go with gorilla tape
Yummy
Yummy
Left inlet ramp and new angle riveted together
