-Finished fitting the 3 support brackets for the filter element -Drilled the holes for attaching brackets to the snorkel and to the inlet ramp -Fit the bottom cowl. Had to do alot of trimming on the left inlet to get it to fit. Then I had to trim the flange on the snorkel to match the servo - it was hitting the bottom of the cowl and I had planned to trim it anyway. -Dimmpled the brackets -C/S the snorkel -Riveted on the aft bracket to the snorkel using the supplied blind rivets.
