Brent s RV-8 Project N784DE
Date:  7-24-2010
Number of Hours:  1.90
Brief Description:  Crankshaft rear plug install
-Worked on installing the rear crankshaft plug. I ended up having to emery the plug on a drill press to get ride of a little material - it wouldn't fit. I sent about an hour chasing my tail on that one.
-Used two drifts to drive it into place (one above and one below the oil tube).
Worked like a charm. I still need to put the pipe plug in that goes in the center, I should have done it before installing it, but I thought the hole would be handy if I needed to get it out if it got stuck crooked or something.
1.25" plug installed
Here's the little pipe plug that goes in the center
