Slept in so I only got :30 on the plane this morning. Another 12F morning as well. Put the rubber channel on the fuel pump and filter brackets per the plans and loosely installed them with the provide hose clamps. I then layed out and cut the return line that runs back to the andair fuel valve (AN swivel T from Vans attached to the bottom of the selector valve). Per the plans you have to flare this line and the main feed line in place because they run through the left gear tower - fun! The good news is the is almost a straight shot on the return so no bends. The feed will have some minor bends from what I can tell - I'll find out tomorrow.
The return line poking through the gear tower ready to be flared
