Brent s RV-8 Project N784DE
Date:  10-24-2009
Number of Hours:  0.80
Brief Description:  Reinstalling the flight controls #2
More of the same. I put the controls back into the fuselage today and hooked everything back up. I still need to put the tail feathers on so I can rig everything. I used a slight coat of grease on the washers to hold them in place when I stabbed the bolts - worked great! Also since the weldments were squeezed together from the previous assembly, I made sure they were spread out enough to allow the washers to go in without binder. Once torque is applied the weldments will clamp back down on the rod ends and washer by design.
Controls back in place. Note I have the front stick bungeed to the crossbrace so it can't flop around
Another angle
Another angle
