Brent s RV-8 Project N784DE
Date:  9-7-2009
Number of Hours:  9.20
Manual Reference:  10-3
Brief Description:  Canopy Finishing
Since my work has been in lots of short spurts and it's pretty redundant - add material and sand it back off - repeat often, I thought I'd consolidate Aug 23 to Sept 7th.
I used micro balloons mixed with West Systems resin to work as filler for the low spots and used a skim coat of epoxy to fill in the pins holes. I not exactly finished, but it's suitable to put away and work on something else for a while.
One of the things that make it difficult is the consistency of the micro, too wet and it runs and is hard to sand, too dry and it won't lay down....
This pic shows one of the earlier iterations of micro and sanding -note the joggle for the center rail
Adding a slurry of dry micro.
Here it is before I took it off and put it in storage.
