My friend James 'Slim' Savage came by to check out the bird and I took advantage of the 2nd set of eyes to do anther engine run to prove yesterday wasn't a fluke.
It fired up without too much hassle and then sumarily quit - I forgot to turn on the fuel - duh! So I started it again and ran it for about 5 minutes complete with an 1800-1900 rpm runup. Prop and mags checked good. The fuel pressure (psi) is still sky high, not sure why. It runs fine. Gotta do some digging on this..
Note the high fuel press (47 psi). Everything else is normal. This is just after startup.
