Brent s RV-8 Project N784DE
Date:  7-23-2011
Number of Hours:  5.60
Brief Description:  Interior panels, wheel pants, fairings, covers
Again lots of little stuff. I didn't have enough panhead screws to secure the interior so I skipped around alittle.
-Installed the gear tower covers. Put a robber liner on the right one to protect wires - see pic 2.
-Installed but only put a couple of screws into the rear bagg compartment parts (3).
-Insatlled with only a couple of screws the fwd seat ramp pieces and rear rudder guides.
-Made spacers for the Crow seat belts (2).
-Installed the wing root fairings with cleco's. I lost the gasket somehow so that is on order. Need that before I can screw them down
-Torqued and safetied the brake caliper bolts
-Cotter pinned the wheel nuts
-Aired up the tires to 49 psi
-Installed the upper intersection fairing. I need to put a screw in the front to pull it up tight, especially on the right side. Didn't have the ss screws on hand for this either.
-Installed the right wheel pant. Started on the left one before I had to get home.
Rear bagg
Rear bagg
Right gear tower cover on.
Right wheel pant
Right wheel pant
