Brent s RV-8 Project N784DE
Date:  7-21-2011
Number of Hours:  4.10
Brief Description:  Floorboard, wiring, F804 bulkhead covers, batt tie
Consistent with the theme of lots of little things getting done:
-Had to removed the fwd floorboard cause I realized I didn't wire the rear 12v socket!! Duh!
-Wired the rear socket
-Resecured the fwd floorboard- lots of screws
-Installed the F804 bulkhead covers with the specified blind rivets.
-Secured the battery. Put a rubber booty on the positive terminal.
-Vacuumed the rear tail cone
-Put another cooregated plastic conduit on one of the rear wire runs that didn't already have one.
-Started putting screws (lots of them) into the right wingtip.
HOT - 97F I like it!
Under flor wireing and controls - all done!
Did I mention it was hot in the tailcone!
The righ side F804 riveted on. I moded mine with the ELT controller and a map/flood light.
