Installed the elevators. The counterbalances are alittle light so I'm going to add some washers under the counterweight hold-down fastener. Everything attached and torqued at this point -Installed the vertical stab. Torqued -Started on rudder and realized I didn't get the position light wire inside the rudder extended to meet the pigtail from the fuselage. Didn't have my wire at the hangar -- moving pains, so I moved to the pitot. I have the pitot installed including the wiring. Just need to put in the screws real quick.
Next session I'll knock out some of these loose ends and get the wing control surfaces on - hopefully!
Elevators and vertical on
Pitot plumbing and wiring hooked up and ready to go.
