Brent s RV-8 Project N784DE
Date:  4-14-2011
Number of Hours:  1.10
Brief Description:  Wing attach details #1
-Used my homemade hole locater to mark 22 holes on the bottom fuse skin to match the wing skin holes along the root.
-Center punched and then drilled the holes #30 for now per the plans.
-Moved to the fwd tank to fuselage attach brackets. Initially it looked like they fit pretty good (plans call for using a hammer/mallet to open or close the angle so it's flush with the mating tab coming off the fuel tank and the side of the fuselage). I end up having to open up the angle very slightly by hitting it hard with a mallet with it laying open side down on the floor. Next step is to do the left side as needed and then try to get to the holes that need to be drilled (access won't be fun around the fuel system on the left and the wiring on the right)
Using the hole locater to match the holes underneath
Holes drilled (22)
Holes drilled (22)
The bracket I'm working on is the one touching the side of the fuselage.
