Brent s RV-8 Project N784DE
Date:  4-6-2011
Number of Hours:  2.20
Brief Description:  Wing install prep #2
Cut the threads off the hardware store 7/16 bolts to use as pins for temporarily installing the wings.
Worked on leveling the fuselage (should have done this off the gear - it's tall!
Removed the fwd floorboard and removed the center section spacers
Cleaned up the center sections (dust and junk accumulated down there)
Cutting off the hs bolt
This will keep the threads from galling the holes
Tail is starting to get close to the ceiling
