Brent s RV-8 Project N784DE
Date:  3-26-2011
Number of Hours:  1.00
Brief Description:  Mid canopy latch #3
-Bolted the latch onto the right hand roller. Put the canopy back on to test fit it. Looks like no additional trimming required. I then drilled the holes for the roller to attach to the canopy frame. I used pit pin T-handles so I could jettison the canopy in an emergency. I'm happy with the results thus far. The pit pin are slightly long, so I'll put an o ring on the shaft of the pin to keep them from vibrating in and out - won't affect the egress capability. I also worked the pin that engages on the center track as it's rubbing the track slightly- still rubs...
Still need to locate the latch stop hole somewhere along the right canopy rail.
Latch loosely in place (note it's not flush at this point)
The right side drill and pin in place. Slightly long so an O ring will keep the handle flush
On the left side. Scatch marks are just masking tape residue.
