Brent s RV-8 Project N784DE
Date:  8-31-2010
Number of Hours:  0.50
Brief Description:  Cowling #15
-Mixed up a batch of mirco to fill some of the areas around the spinner and intakes that didn't match between the top and bottom halves post installation. I also put some micor on the layup I did to repair the bottom right side of the cowl where I trimmed it too far.
Once the mirco set up to the consistency of cold peanut butter I took a knife and scribed the joint at the seam between the top and bottom halves and and separated them before it cured. Next step will be to put them back together and sand them as one piece to get the transistions nice and smooth - relatively speaking....
The white is hte mirco along the joint - I did this off the plan since the prop is installed
Area where I had previously added fiberglass and now I put micro on and I'll sand and repeat
