Brent s RV-8 Project N784DE
Date:  6-24-2010
Number of Hours:  1.20
Brief Description:  Empennage faring #6
-Pulled the peel ply away from the newly laid up parts of the fairng
-Broke the fairing away from the fuselage
-Trimmed the part using tin snips (probably not good for my tin snips - oh well I have the dust from the dremel.
-I then rough sanded with #36 and reinstalled on the airplane
-Drilled the lower fairing attach screw holes and cleco'd it on.
Next step - coat it with dry micro and start the sand - coat - sand - repeat exercise.
Here is is roughly trimmed up and sanded.
Lower part of the now one piece fairing
It's pretty rough when you first remove it from the airplane.
