Back to working on the fwd upper fuselage. I need to get that taken care of so I can work the canopy and winshield (along with the turtle deck). -Cleco'd the top of the bulkhead the defines the aft wall of the fwd bagg compartment and the rear of the instrument bay. -Cleco'd the instrument panel in place with the center panel installed 1 screw hole low per the plans. -Bolted the windshield bow weldment in place (used a cheapo cordless screwdriver to tighten the bolts and it saved a bunch of time and torqued them pretty close to the exact amount (25 in lbs)).
