Brent s RV-8 Project N784DE
Date:  5-8-2009
Number of Hours:  1.70
Manual Reference:  MOD
Brief Description:  Rudder Pedals #7
My order from Aircraft Spruce came in which included .125 6061T6 aluminum 2'x2' plate that I will use to fabricate rudder pedal extensions al la Randy Levold's. I layed out the dimensions on cardboard and then transfered that to the metal. Cut out the pieces on the bandsaw and finished them on the 3M wheel. I bent them to 40 degrees on the vice with a deadblow hammer. Looking good so far, probably another 1.5 and they'll be finished.
Here's the pattern and one of the blanks I cut out of raw stock.
Here are the left/right blanks after bending the bottom 1
Here are the left/right blanks after bending the bottom 1"
Here's how they fit, minus the bottom plate that will attach.
