Brent s RV-8 Project N784DE
Date:  4-26-2009
Number of Hours:  0.50
Brief Description:  Static system install #1
Layed out the hole location for that static port on each side of the fuselage. Started with #40 and stepped up via #30, #19, #12 and then another bit just shy of 1/4" and then used a 1/4" reamer to finish them off. Deburred.
The tiny red dot near the vertical line of rivets is where the hole will go on the right side.
Finishing the job with 1/4
Finishing the job with 1/4" reamer.
Here's where the static port will go in the inside.
