Bolted the windshield frame to the fuselage - I had originally cleco'd it, but once I start putting on the F821 top skin I realized that wasn't going to work.
Then I finished up clecoing the F821 to the fuselage - looks cool! -I located the baggage compartment door hinge support and spacer and removed the plastic -Final drilled #30 the two holes on the forward end of the support and deburred and dimpled. Ended up dimpling the wrong end so I had to squeeze out the dimples and repeat those steps to do the actual fwd end - duh! Worked out ok.
Top skin viewed from the left. Note the large fwd baggage opening.
