Brent s RV-8 Project N784DE
Date:  3-1-2009
Number of Hours:  1.10
Brief Description:  More random stuff
Started working on some of the bulkheads. I dimpled the F807 for flush rivets where the seatbelt fairleads are installed. Machine countersunk the fairleads and reprimed. Then I deburred the F889 gussets that get installed on the F807. It allows for storage of the tie down rings when not in use so I started fabricating what amounts to large thick nutplates to accep the 3/8 -16 tie down ring threads. I marked them off, cut the big holes and tapped to 3/8-16. Then I cut out one on the bandsaw. Still more work to do before these are ready.
Rear shoulder harness fairlead rivet holes dimpled.
Rear shoulder harness fairleads countersunk.
Roughed out nutplate to secure one of the tie down rings to the F889 gusset.
