Brent s RV-8 Project N784DE
Date:  2-3-2009
Number of Hours:  1.30
Manual Reference:  8-57
Brief Description:  Control System Installation #7
-Final drilled #12 (used 3/16 reamer) the rod end bearning holes in the WD807 control column
-Final drilled #12 (used 3/16 reamer) the holes in the WD807 control column used to attach the aileron pushrod assemblies.
-Removed the bushings from the front and rear sticks and filed them down with a sander to fit within the WD807 control column lengthwise. Lots of trial and error here.
-Did the same with the control sticks (made them slightly shorter than the bearing (careful not to remove too much material here).
-Reamed the bushings to accept the AN4 bolts (1/4")
-Bolted the front stick to the control column
Control column and associated parts.
bearing and stick sanded down to fit within the WD807
Front control stick bolted to the WD807
