I worked on the project early again and Greg came over to check out the laser level. I double checked and fiddled with the alignment and then drilled the two holes that were 1 23/32 above the single hole (thanks Jeff Preou for your excellent documentation of this error in the plans on you website! http://www.mykitlog.com/jpreou. The VS is straight and the edge distances were fine on the tailwheel weldment so I'm happy. I drilled those two holes out to #30 and then drilled all 3 hole out to #12 and installed AN3 bolts temporarily. I was good to have Greg over and catch up on the building stuff!
