More work on the rear seatback. I removed the eyelets per the plans on the bottom hinge. Then I marked off and drilled the alignment holes in the hinge as noted in the drawings. Then it was cleco it together, drill the hinge rivet holes. Bend the top of the F833C with the flanger per the plans and match drill the whole thing. Syndey came out and lended a hand on the cleco pliars and Mary did duty handing Syd cleco's. Just like an assembly line! Happy Thanksgiving!
The rear seatback assembly
I'm drillin the hinge while Syd throws cleco's in the holes.
Mary came out later and handed Syd cleco's - Syd's such a ham
