Brief Description: Riveting seat rib outboard rib in place
This entry was actually spread out of 2 day (12th and 13th) Riveted the outboard ribs to the seat rib assembly as shown below. I squeezed the universal rivets that tie it to the rear spar carry-through and torged the AN3 bolts to spec. I then shot the flush rivets that attach the rib to the bottom skin. Since I haven't primed most of the fuse parts I'm quickly running into a standstill and unfortunately rain is forecast all weekend (and I dont like priming inside).
The outer most rib is what I'm attaching today (between the triangle piece & the gold.
