-Final drilled the bottom mid fuselage skin to the center section from below (that's why I had to put the fuselage on saw horses) -Cleco'd the turtle deck skin on. -Cleco'd the aft most bulkhead top F810, F810D spacer and F819 aft deck into place. -Transferred the notches in F819 to the longerons for trimming -Match-drilled the upper longerons to the F819 using the holes in F819 per the plans. -Marked the longerons at the aft face of F812 for trimming. -Cleco'd F812B-1 angle control stop onto the F819. -Cleco'd F811C-1 and F811D-1 control stop to the F819 as well.
Cooper cleco's represent the holes drilled from the bottom skin into the center section.
Putting on the turtle deck - I love visual progress!
Match-drilling the upper longerons to the F819 aft deck.
