Brief Description: Adding Tailcone to FWD Fuselage #3
-Inserted the upper longerons per the plans. Looks like it's going to need virtually no tweaking. -Edge deburred the cockpit rails and the center section bulkhead caps on the 3M wheel and then with a file. -Cleco'd the bulkhead caps and the cockpit rails in place per the plans. -Adjusted the upper longerons so the reference mark used to bend them was lined up with a slot that was manufactured into the cockpit rails - looks good!
Upper longerons in place.
Deburring one of the cockpit side rails.
Cockpit side rails and the left bulkhead cap shown.
