Brent s RV-8 Project N784DE
Date:  6-28-2008
Number of Hours:  2.60
Manual Reference:  8-21 & 8-22
Brief Description:  Tailcone Bulkheads #2
Up early this morning (4:30ish) with plans to make big progress. I did pretty good.
-Deburred and radius the parts that I cut away from F-800 (see previous entry).
-Cleco'd F812A-1 and F-812C-1 together and final drilled #30.
-Used a hand seamer to match the flange on 812A to 812C.
-Layed out and match-drilled the WD-409 tailwheel forward mount to the F-812 bulkheads - this took some time to do correctly, you don't want to screw this up. I won't rehash it here see Jeff Preou's excellent weblog on this:
http://www.mykitlog.com/users/display_log.php?user=jpreou&project=45&category=2153&log=35967&row=223
just cut n paste it into your browser.
-Machine countersunk the 2 holes from the previous step.
-Disassembed and deburred the F-812 bulkheads and the tailwheel mount.
-Dimpled the F-812s for flush rivets on the aft side.
-Scuffed and cleaned the F812s and used a wire wheel to remove the mill scale on the tailwheel assemble (I dissasembed all of the parts - watch out for the sping and shear pin I will fly out and you could lose them).
- Primed the parts from above.
-Radius'd the F-811 stabilizer attach bars
-Trimmed the F811s per the plans on the bandsaw - very easy.
-Cleco'd the F-811A & 811E and the stab bars.
-Final drilled the 811s together.
-Started Match drilling the 811s to the stab bars. The bars are pretty thick and you have to use the pilot hole in the sheet metal and I was worried about straightness when I remembered the handly pilot tool that I bought at OSH last year to ensure straight holes - worked great. If you don't have one get one - not expensive.
A load of hay showed up (100 bales) so I had to stop for now.
Tailwheel clamped to the F812 bulkheads in preparation for match drilling.
parts primed.
parts primed.
You can see the pilot tool just above my hand (clear plexiglass)
