Brent s RV-8 Project N784DE
Date:  6-20-2008
Number of Hours:  1.50
Manual Reference:  8-19
Brief Description:  Mid Fuselage #3
-Cut the slot out of the middle left rear armrest for the rear seat throttle - turned out pretty good.
-Bent the mid fuselage side skin per the plans. It called for marking the skin at the bend line and then clamping a beveled 2x4 in place with the line matching up to the edge of the bench. Then I installed the angles on the outter edge for the sole purpose of twisting the skin to comform with the F-807 bulkhead. When pretty good, not perfect but the holes did line up adequately.
Slot for rear seat throttle.
Left skin layed out and clamped to the bench.
angles installed (one on top and one on bottom.
