-Riveted the vertical bars onto the aft center section assembly. The rivets are short so go easy.
-Finished riveting the seat ramp supports using the offset rivet set in the gun - I hate that thing, hard to keep straight on the rivets. These came out good with no smileys.
-Put the AN5-11A bolts into the forward section per the plans. Torgued to 40 in/lbs and torque locked them.
-Put the seat ramp bolts in AN4-11A finger tight per the plans.
Backriveting the vertical bars (on the bottom side).
Put the 1/4" bolts in per the plans and torque locked them so I know they were torqued.
