-Drilled the 5/8" holes that go through the center section for the rudder cables.
-Cut two spacers that go into the center section.
-Deburred the front seat belt center mount brackets
-Fabricated the front control mount that goes onto the center section. That took alittle time to lay it out and cut it out of raw angle stock. Turned out pretty good.
-Match drilled the control mount to the forward center section.
Here's the center section parts.
Drilling the rudder cable holes with the uni-bit (carefully).
Control mount bracket that started at raw aluminum angle. It's drilled and ready to go.
