Brent s RV-8 Project N784DE
Date:  4-23-2008
Number of Hours:  2.60
Manual Reference:  8-6
Brief Description:  Gear Tower - Assembly #13 (finished)
Lots of progress today. Mary even came out and helped me part of the time.
-Radiused the edges of 8 washer for bolting the forward and aft upper cross braces (allows the washer to set flat due to the radius of the corner angles).
-Riveted the Forward upper brace (F-802N-1) and Aft upper brace (F-802T-1). Had good results as I was able to squeeze these).
-Put all of the AN-3 bolts in for both items above.
-Riveted the throttle quadrant bracket to the left gear tower. Then added the nutplates to the bracket.
-Riveted the nutplates to the mid-cabin braces (I left the ones near the attach rivets off so I could have plenty of room to buck the big AD4s that attach the braces to the tower - bad move, I had to end up bucking the nutplates due to clearances isses with the squeezers).
-Bucked the mid cabin brace rivets that attach them to the their respective gear tower. Came out good. Drilled out one rivet, but not a big deal.
-Put the bolts into the mid cabin brace that tie the to the WD-812 weldments.
-Installed the final 4 nutplates on the mid cabin braces (had to buck them).
See the other entries for additional pictures.
Radiused washers on the bench grinder.
Squeezing the upper brace rivets.
Upper bracket locknuts and rivets (from the inside).
