Second session modifying the gear towers to allow access inside. This morning. I used the right gear tower lower web piece to duplicate the holes onto the left tower cooresponding part. I then made a blank of the doubler from the right tower and match drilled it to the lower and then used the removable part of the web from the right tower to match drill the left and I continued this process for the upper part too that needed a doubler - see photos. I am ready to starting drilling for the nutplates next session. I actually countersunk some of the holes per the plans on the right tower with the extra few minutes I had.
I have the different parts of the web cleco'd toghether to match drill and the doubler -left and right
Here what it will look like with the 'cover' removed.
Countersinking some of the nutplates rivet holes in the RH tower per the plans
