Started on the forward floor today. Took a few minutes to find the parts and get oriented with the plans. The new fuselage plans are far superior compared to the older one. I am going to try and add more detail into my entries going forward.
-Final Drilled and machine countersunk nutplate attach holes for F-802K-1L and F802L-1
-Cleco'd together F-802K-1 (fwd crossmember), F-802L-1 (aft crossmember), F-836L and R (floor ribs), and F-802M-L-1 and R-1 (intercoastal ribs) together F-822-1 (fwd floor panel).
-Matched drilled all of the components above.
-Final drilled the 1/8 holes in F-822-1 (fwd floor panel) per the plans.
-Final dilled the 3/32 nutplate attach holes in F-822-1 (fwd floor panel) per the plans.
-Final drilled the 3/32 hole in the F-836-1-L and -R (floor ribs) per the plans.
