Brent s RV-8 Project N784DE
Date:  2-20-2011
Number of Hours:  1.00
Brief Description:  Brake Lines - Grove gear
-Not much real work done on this session. I spent most of my time figuring out that I couldn't fabricate a hard brake line that would connect the grove gear to the bulkhead AN4 brake line fitting coming out of the bottom of the fuselage. There is no room to bend a curved or looped line to connect the two so I'm going to get a ss flex line to put in there and hopefully that'll do the trick.
If I would have put a 90 fitting on when I installed the gear I would have been better off, but I think I'll be ok.
The two fittings I'm trying to connect.
