I got up late so I didn't try to tackle too much. I cleco'd the left wing aileron brackets together with the bearing installed. I also test fit them to the wing. As my buddy Mike had warned me the bracket was tilted inboard alittle. I will straighten that up before I rivet everything together. Also I started unscrewing the fuel tanks so I can countersink and rivet the most forward rib flange holes. Somehow I missed those when I was building the skeleton - no biggee just time.
Cleco'ing the left wing aileron brackets together.
outboard bracket cleco'd to the wing.
Note the bracket is tipped inboard ever so slightly.
