Well I slept in again and didn't get much done. I did manage to fabricate the flap angle brackets out of angle stock and then bent the FL-406Bs that attach to each flap to 6.3 degrees from 0 to line up witth the inboard flap rib. I then started to match drill the angle bracket and 406B to the right flap. As a point of reference, this is the first day I cranked up a heater. I isn't the coldest I have seen this fall, but it is so damp today I needed something to break the chill. Winter #2 is coming in the unheated garage!
Cutting the FL-406A reinforcement brackets out of angle stock.
Done.
Match drilling the angle bracket from prev pics and FL406B to the left flap.
