Brief Description: Aileron - drilled hinge brackets and primed (left/
Worked on match drilling the aileron hinge brackets (4). I then countersunk the inboard reinforcements to accept a nutplate in each one(2). I screwed up and one was upside down when I countersunk it so I got to throw that one away and quickly make a new one. Once I got caught up, I deburred all the holes in both the bracket and the spar and then scuffed, cleaned, and primed. I spot primed the areas to be riveted, but I will go back and prime everything before closing up the aileron(s).
Match drilling for the hinge bracket.
Countersinking the reinforcement bracket for a nutplate.
Primed the brackets and spot primed the spar.- more priming to come.
