Worked on re-aligning the wing in the jigs, don't want any unpleasant twist or other nasty issues. Once things get riveted on, it's too late to change it. I have the left wing pretty well dialed in and tomorrow I'll work on the right wing. Once that is done it's time to install the leading edges.
plumb bobs are dropped at each wing tip and measurements from the string to the rear spar are compared
