Worked on some of the misc fuel tank items this morning. Notched the vent line grommets for the sending unit wire. Cut the poly tube into 15/32 long sections for use in mounting the capacitance plates. I installed the grommets and did some head scratching on the order to install everything so I don't get into a corner.
Putting a notch in the grommet that holds the vent line. Notch is for sending unit wire.
Note white wire going through the grommet with vent line.
Cut 15/32 spacers out of tubing supplied for the capacitance plates.
