I made good progress this morning. I managed to get all the prep work done on the right leading edge. I removed it from the wing, uncleco'd, removed plastic at the rivet lines, deburred, scuffed for primer, dimpled, and primed all in one session. All that is left is to cleco it together and then rivet.
Everything un-cleco'd, plastic removed on the rivet lines, and deburring.
Note the rib on the bottom has been relieved to avoid bumps in the leading edge vs the top rib.
Top phot is dimpling the skin, bottom shows all the parts after priming.
