Brent s RV-8 Project N784DE
Date:  5-28-2007
Number of Hours:  3.00
Brief Description:  Misc Fuel tanks #2 plus leading edge prep work
Had a good 3 hr session this morning. I was able to get a few of the small items done on the fuel tanks. I am about to the point where I can't do much else until the ProSeal arrives.
-Drilled the 3/8 holes for the BNC connector on each tank (fuel quantity sending unit). I then mocked up and trimmed the capacitence plates (outboard ones) so they didn't interfere with the fuel tank stiffners. I then moved onto the fuel pickup for the right tank (I am using a conventional pickup on the right and a flop tube on the left). I fabricated the tube and put all the hardware together. I still need a flaring tool to flare the tube before I can install everything. From there I put away all the fuel tank parts and moved the left wing leading edge onto the bench and started removing the plastic on the rivet lines.
Fuel tank capacitence senders trimmed (outboard)
pickup tube on the right tank
Removing the protective plastic from the rivet lines on the left wing leading edge
