Brief Description: Riveting the left wing skeleton #2
Continued to rivet the left wing main ribs to the front spar this morning. I only have 5 ribs left for the spar and then I will go back and rivet the rear spar onto the ribs. Good progress!
Note hardended steel block below the spar used as a bucking bar.
Almost done - 5 more to go. Note the ribs aren't straight up and down at this point.
