Brent s RV-8 Project N784DE
Date:  1-18-2007
Number of Hours:  0.60
Brief Description:  Wing spar counter-sinking continued #7
Got all the access panel nut plate #6 screw attach holes counter-sunk this morning. Got up late and had a couple of other things to do so I only got :36 minutes in. Next step is to counter-sink all the little -3 rivet holes (2 per nut plate). There is probably a 100 of those, but they should go fast as they are small.
Close up of the #6 screw hole counter-sunk with a #40 counter-sink cutter with jig in place.
Aligning the counter-sink jig by cleco'ing into place and then clamping and then removing the clecos.
