Brief Description: Riveting right elevator substructure
Wasn't feeling the best this morning (sore throat) so I slept in and only did a couple of hours riveting the right elevator. Riveted the counter-balance ribs together, riveted the elevator attach doublers into place along with the required nut plates, and riveted the inboard rib to the spar. Descent progress. Next session I will need to attach the right side elevator horn, counter-balance weight cover, and start skinning. I need to remove some material per the plans on the counter-weight.
Flush riveting the inboard rib to the spar on the right elevator
Squeezing univeral rivets for the elevator attach doublers
