Brief Description: Preping Right elevator under structure
Took a break yesterday but I was back out there again this morning at 530am. I removed the protective plastic from the right elevator under-structure. To my suprise I found a bad scratch on the spar. I polished it out with a scotchbrite pad on a 90 degree air grinder-worked fine and the scratch is gone. I beveled the counter-balance weight cover per the plans. I then counter-sunk the rear spar to inboard rib attach and deburred all of the under-structure.
Nasty scratch on the right elev. spar, not sure how it got there.
Beveling the edge of E-713 (counter-weight cover) where it lays under the skin.
