Brent s RV-8 Project N784DE
Date:  8-5-2011
Number of Hours:  4.70
Brief Description:  1st Engine Start
First session this morning:
-put on interiror placards
-put the front seat ramps and cushions back in
-checked the starter circuit - it cranks!
-more FWF securing
-Put 10 gal per side in the tanks - no leaks!
That evening I came back out and Jim Baldwin and I ran the engine for the 1st time - magical.
Initially presurized the fuel system and had a leaking fitting - fixed that and....
crank, crank, crank starts roughly, then picks up. Oil pressure is good, fuel press is high (I'm researching this), everything is great!!! I run it for less than 5 minutes and shut it down to inspect.
Post engine run! It was just me and Jim so no action photos - he was on the extinguisher
Some of the many placards
Putting on fuel this morning
