Brent s RV-8 Project N784DE
Date:  1-30-2010
Number of Hours:  5.00
Brief Description:  Wire routing #9 (flood lighting and intercom)
-Splice the nav light wires together
-Finished up running the wires to the respective flood lights and switches and normal lights.
-Worked on wiring up the intercom harness. 5 connections done with 10 to go. I probably should have sprang for the $200 pre-done harness from Stein or Vans. But all this wiring on the intercom is good practice.
Wires running up the left side that go to the flood light switch, fwd map lgt switch and left console
Intercom harness going togther - the shielding is being connnected together w/jumpers complicating it
Schematic for Flightcom 403 stereo intercom
